Lifting Pucks.......Cheap
Norm
I've done this many times on many later model Corvettes. The below procedure is meant to stay on, but can be removed if necessary. Not all shops use pucks, gives just enough clearance for the lift arm to secure under the frame, therefore not damaging any plastic parts or bottom runners. Where the lifting pucks are located, are the recommended lifting points.
The expenditure should not be anymore than about $20, 4 hockey pucks (drill out a center hole) 4 fender washers to accommodate (4) 1/4x20, 3 1/2" long toggle bolt setup.
002.jpg 003.jpg 004.jpg 011.jpg 015.jpg 016.jpg 034.jpg 035.jpg 036.jpg 037.jpg
