 Ian Allan Motors
» New Unexpected Owner of this C3!! by Lomaximus on Sat 19 Jan 19 21:55
» CCCUK Website and Forum by kentvette on Sat 19 Jan 19 21:26
» This seems very cheap for a C7 by GCVETTE on Sat 19 Jan 19 15:10
» Drifting your Corvette by Mule on Sat 19 Jan 19 11:23
» What did you do with your Vette today? by Nick B on Sat 19 Jan 19 09:35
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 18 Jan 19 20:19
» Any interest in used Z06 suspension? by Ph300zx on Wed 16 Jan 19 22:44
Harmonic balancer
Go to page: 1, 2 / Next
Sierra
Regular
Thu 19 Apr 18 19:32
Harmonic balancer
Iím a bit concerned as my balancer seems to have a slight wobble and thereís lots of horror stories over in the US.
I have a few questions
Does anyone know a garage/price on fitting a new balancer?
Is it worth upgrading the cam while the garage is already working there? (My car will soon be turboíd so a cam may work well also).
Thanks
Steve
BlackZeD
Thu 19 Apr 18 19:48
Re: Harmonic balancer
Mine fell off last September while I was at a show.
Its quite a time consuming job which includes removing the steering rack.
I put an ATI 10% underdrive pulley on it when it was done.
Not a cheap job.
Up to you on a cam, I didn't have mine changed then.
Don't take life too seriously, after all, your not coming out of it alive.
Sierra
Regular
Thu 19 Apr 18 20:11
Thanks, who did the job and how much was the labour?
BlackZeD
Thu 19 Apr 18 20:36
It was done by AAS in Newcastle.
Think off hand the labour was the thicker end of £700.
If you have had a sort of chirping sound from the engine bay it knackered.
I heard it but didn't connect it.
Sierra
Regular
Thu 19 Apr 18 21:11
I havenít had any noise at all, just after seeing a post online decided to have a look at mine.
Vetteheadtony
Fri 20 Apr 18 00:25
Doing mine at the moment, new GM balancer and bolt from Rockauto to my door with shipping and rip off tax £100, as for the job it does seem itís a time consuming job as mine is also ProCharged ( loads more shite to remove) and the rack has to be dropped but not removed as I have been informed. But if your a bit clued up definitely doable.
Iíll see how I get on over the weekend!
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
robbiew
Fri 20 Apr 18 17:31
Very easy to get concerned about this
However because there is rubber in the pulley mounting even a new one will wobble a tiny bit anyway
You should be listening for the belt making a noise and running out of alignment. My c5 pulley moved forwards towards the steering rack. They can also move back !
Ph300zx
Regular
Sat 21 Apr 18 09:29
As above, mine also moved forward (C5) and I only realised when it hit the steering rack! No belt squeel at any stage, original balancer had done just over 50k. Wasn't aware of the issue before buying the car so hadn't been looking for it.
After much messing about trying to get an aftermarket one I went with the OEM one from Eurovettes, Keith often has these in stock ready to go. No need to get hammered with the import tax.
Took mine to my regular garage, talked them through the process from what I'd researched and they were happy to do it, no issues at all.
If you have the space and equipment deffinatley doable at home, just a pain with what you need to remove to get at it.
Vetteheadtony
Sun 22 Apr 18 19:39
Well hereís where Iím at, 3 hours and 7 bottles of Stella, rack, sway bar and power steering pump out.
Power steering pump removal not needed but I wanted to replace the plastic pulley with a billet one, now I can finally see the balancer, Yee Haw!!
Steam cleaned it all underneath ready for it all to be put back together but not gonna rush as Iím gonna paint a few things and change the crank seal also whilst apart.
Last edited by Vetteheadtony on Sun 22 Apr 18 19:42; edited 1 time in total. [11 %]
Vetteheadtony
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Sierra
Regular
Sat 28 Apr 18 19:38
Wow that looks intense
