» New C4 purchase by nickjames on Sun 19 May 13 14:25
» Expansion tank cap - don't suppose anyone has one? by fat_jogger on Sun 19 May 13 13:13
» My in car gadgets by dex99 on Sun 19 May 13 11:33
» Engine stumbles and dies at junctions, in traffic etc. - Help by roscobbc on Sun 19 May 13 01:52
» Supercar Siege, 18th May, Leeds Castle, Kent by RobsVette on Sun 19 May 13 00:49
» Top service from Lincolnshire Corvette by marke144 on Sat 18 May 13 23:59
» Change of car! by Blackadder on Sat 18 May 13 23:20
» American Car Speedfest on Sunday 9th June 2013 at Brands Hatch by Des on Sat 18 May 13 23:08
» 2013 CCCUK Race Series by c5blo on Sat 18 May 13 21:53
» Club update from oilman @ Opie Oils by oilman on Sat 18 May 13 19:08
» Fins n Chrome by BlackZeD on Sat 18 May 13 11:52
» Ignition Barrel by zuko on Sat 18 May 13 11:39
» That time of the year... by thenobbler on Sat 18 May 13 10:57
» Baltic cruise by TexasVette on Sat 18 May 13 10:39
» c4 Auto Transmission Filter / Oil Change by adi4 on Sat 18 May 13 10:31
» C6 door "handles" by Blackadder on Sat 18 May 13 06:55
» Corvette Club de France 60th Anniversary Show, La Ferté Gaucher circuit, August 31st to Sep 1st by JonnyC4 on Fri 17 May 13 16:30
» Ragley Hall Classic Car and Transport show 26th and 27th May 2013 by malcy on Fri 17 May 13 15:30
» C3 (and other generation) parts for sale by Mightygeorge on Fri 17 May 13 15:16
» Jokes - May '13 by Daytona Vette on Fri 17 May 13 13:37
» Fastlane 2013 by 666Vette on Fri 17 May 13 12:49
» Essex Section Monthly Meeting by Des on Thu 16 May 13 20:29
» Thames Valley Meet - The Novello, Maidenhead SL6 3RX by VetteWeekend on Thu 16 May 13 18:45
» Pratt & Miller C6RS for sale by chevrolet on Thu 16 May 13 17:40
» Corvette C6 Wanted by gordon hall on Thu 16 May 13 11:17
» Tyres for C3 by Daytona Vette on Thu 16 May 13 09:21
» C3 Exhaust manifold - tubular by roscobbc on Wed 15 May 13 18:57
» Timing.....whats going on???? MOT tomorrw...... by roppa440 on Wed 15 May 13 16:30
» 2013 NATIONALS, By the organizer ! by RED MIKE on Wed 15 May 13 15:59
» Corvette C4 (1992) Wheels by voguev8 on Wed 15 May 13 10:39
Alternator Light Flashing
pug_crew
Thu 26 Jul 12 22:03
I have found that when I am on a long run on a motorway my alternator light sometime flashes on and off at about a rate of once a second. My voltmeter needle flicks back and forth as well. It seems to happen when travelling at a constant speed of around 60. It is not all the time and after I sort it as described below it may start after about 15 or 20 minutes.
At first I put it down to a loose battery connection as I tend to leave one terminal hand tight so that I can remove it if I'm not going to use the car for a week or so. Each time the problem happened I stopped and fiddled around with the terminal and everything was ok again.
I have now tighten the terminal properly but last weekend it happened again. But every time I stopped and fiddled around with the terminals it was ok again. However I found that stopping the car and starting again 'cured' the problem. I even found that if I slowed down to below 40 the light would stop flashing and I could speed back up to 60 and it would be ok for another 10 or 15 minutes.
Any ideas???
Sat 28 Jul 12 12:37
Re: Alternator Light Flashing
Have you checked the terminals on the alternator, not knowing if your pulley wheel is keyed to your alternator spindle, check to ensure the pulley wheel nut is clamped up tight so the pulley wheel is not slipping.
Could be dodgy Battery or Alternator.
Best of Luck.
Last edited by Daytona Vette on Sat 28 Jul 12 12:38; edited 1 time in total. [1 %]
Barry - Daytona Vette
JonnyBlue82
Future club member?
Sun 29 Jul 12 12:41
If the alternator is old then it may be the slip ring brushes are on their wear limit. I suspect they are probably bouncing off the rings at certain rpm.
Try reving the engine staitionary to the same rpm you were driving at when the problem occurred and see if it does it.
Give the alternator a good wiggle up and down at the pulley to see if there is any play in the bearings, this would have the same effect I expect if it was chattering about. You may need to slacken the belt to see the true wear in the bearings.
Jon
82 Corvette C3 - Just needs waxing + total restoration!
pug_crew
Sun 29 Jul 12 17:48
Thanks for the ideas, I've been tied up on other things this weekend so haven't had the time to check but will do so as soon as I can.
