2012 MOT regs and C4 headlights
Author |
Message |
New Comer |
Thu 27 Oct 11 11:46 2012 MOT regs and C4 headlights Hello everyone - it's my first post, although I've owned the car for a while now.
Club Member |
Thu 27 Oct 11 18:26 Re: 2012 MOT regs and C4 headlights Before going to the MOT Station, raise the headlights then disconnect the motor connectors and flip the lock rings! They will remain up during the MOT.
New Comer |
Fri 28 Oct 11 10:05 Re: 2012 MOT regs and C4 headlights Thanks, that should work. Certainly going to be easier than rewiring the switch or trying to move the parking lights into the fog light/indicator units. I really can't understand why they feel the need to add a regulation about the amount the switch has to be moved: if the parking lights work, why does it matter what the procedure for turning them on is? |
Club Member |
Fri 28 Oct 11 14:35 Re: 2012 MOT regs and C4 headlights I only had to fit the side bulbs last year and that was only because the boss walked in as the lights were being done. I'm sure a 'friendly' garage will be ok.
New Comer |
Tue 10 Jan 12 13:03 Re: 2012 MOT regs and C4 headlights I had my 1990 convertible MOT'd last month (Dec 2011) and the tester pointed out that the front side indicators were non-compliant as they could not be seen from the rear of the vehicle. Also, there were no rear reflectors. He passed it anyway as they were minor points.
Awww... join the CCCUK! |
Tue 10 Jan 12 13:32 Re: 2012 MOT regs and C4 headlights BenP wrote (View Post):But next year the MOT test is changing, and there's a new line in the test procedure that reads: "Check that the front and rear position lamps illuminate with a single operation of the switch"
