 Adrian Flux
» Failed oil pump drive by kentvette on Fri 21 Sep 18 17:45
» Amazing by kentvette on Fri 21 Sep 18 17:41
» '95 C4 with LT1 missfire by Lankybloke on Fri 21 Sep 18 16:29
» 1989 C4 For Sale by RickyG512 on Fri 21 Sep 18 14:28
» C8 is Coming by roscobbc on Fri 21 Sep 18 13:51
» Resto Vette - or - Modifed Vette by roscobbc on Thu 20 Sep 18 20:40
» C7 Configurator by c6pete on Thu 20 Sep 18 12:46
» C2 fibreglassing and stuff by L88 on Wed 19 Sep 18 20:50
» What did you do with your Vette today? by FelixP on Wed 19 Sep 18 13:44
» Potential new C5 owner - some basic questions by Le Vette on Tue 18 Sep 18 14:09
» Stunt Driving from 1966 Chevys by Daytona Vette on Tue 18 Sep 18 10:47
» 1966 C2 Corvette Wilwood Master Cylinder by L88 on Mon 17 Sep 18 11:44
» Euro to US tail lights help by julian marshall on Sun 16 Sep 18 11:41
» Mid engined Corvette by Norm on Sat 15 Sep 18 15:19
» C3 Side Exhaust Pipes by CaptainK on Fri 14 Sep 18 13:10
» Presume this is my battery on the way out? :-( by roppa440 on Fri 14 Sep 18 00:02
» [Pics] C6 Corvette's in the UK. by autocolor on Thu 13 Sep 18 19:45
» T-tops - single / double latch by Vetteheadtony on Thu 13 Sep 18 14:06
» Breakfast meet by VetteWeekend on Wed 12 Sep 18 20:20
» Recommended Restorers by CaptainK on Wed 12 Sep 18 12:12
» 1990 L98 C4 not starting by lovejoy on Tue 11 Sep 18 19:28
» CCCUK West Sussex meeting in September by robbiew on Tue 11 Sep 18 18:34
» South Central Regional Meeting for September by Daytona Vette on Mon 10 Sep 18 12:22
» Spare wheel light by fordpop52 on Mon 10 Sep 18 07:14
» My 01 c5 yellow for sale by Celcius on Sun 09 Sep 18 20:58
» For Sale 09 C6 Corvette by John Lynn on Sun 09 Sep 18 01:25
» C2 Bonnets by L88 on Sat 08 Sep 18 22:56
» BBCN Regional meet by autocolor on Sat 08 Sep 18 09:48
» Interesting Article by philv8 on Fri 07 Sep 18 23:54
» Heads/cam by Fraser on Fri 07 Sep 18 16:26
Dead battery
stiej
Sat 12 May 18 22:28
Dead battery
Hi all.
What battery does everyone recommend for an 87 c4? My red top optima is dead. Doesnít hold charge according to my ctek charger. Tried charging it twice. Takes about 24 hours of charging then the charger flags up the failure wth itís red warning light.
What options have I got for a new battery? The optima fits but only just about. I have to have it sitting on top of the outer edge of the battery tray. Otherwise I canít get the negative battery lead on due to the structural brace. Most batteries I see on Tanya.co.uk are 5mm larger than the optima but then they can also be shorter at the same time so I guess the lead would go on.
All help greatly received!
Redlevel
Sun 13 May 18 10:34
Re: Dead battery
Tanya batteries with side terminals will fit fine.. You don't need an Optima battery. The regular ones are just as good and probably the only place you'll get a side terminal battery at a reasonable price and with a decent no-quibble warranty.
Bought two for my '87 and S10 truck which were parked outside and in daily use all winter. No problems.
stiej
Sun 13 May 18 10:39
Re: Dead battery
Thanks. My battery cabling has been changed I think and needs standard top posts. Are the side terminals the same kind of shape and size (kind of like American hard gum shape!)???
What CCA do I need?
Redlevel
Sun 13 May 18 10:53
Re: Dead battery
If you need a standard terminal battery, measure your dimensions needed (there's quite a bit of space in there so a few mm either way shouldn't matter) and check with Tayna what they have that would suit you. You can message them as they are on Fb.
My CCA is about 600 which throws the motor over just fine (it's an easy starter anyway since I refurbed the fuel system and bumped the initial timing from 6 to 10deg)
FelixP
Addict
Mon 14 May 18 09:58
I can also recommend Tayna batteries. Well priced & excellent service
1989 Corvette C4 L98 6 speed ZF with Z51 & FX3
