CCCUK logo
Website Control
Recent threads
New Forum Posts
» Towing solution for C5 Z06 or any non Euro spec C5 by Firepit on Sat 25 May 13 23:45
» C6 door "handles" by Wetterflod on Sat 25 May 13 22:45
» Bentwaters open day 2013 by derock on Sat 25 May 13 20:49
» Fins n Chrome by BlackZeD on Sat 25 May 13 19:10
» Ragley Hall Classic Car and Transport show 26th and 27th May 2013 by malcy on Sat 25 May 13 16:02
» c3 brake caliper by eurovettes on Sat 25 May 13 09:58
» Corvette shoots by JonnyC4 on Sat 25 May 13 09:20
» My 1959 C1 is almost here! by 666Vette on Fri 24 May 13 22:49
» My other bit of fun by 666Vette on Fri 24 May 13 22:16
» Newton longville by petchy56 on Fri 24 May 13 21:52
» CCCUK Tour of the Republic of Ireland 22nd to 29th May 2013 by tiger289 on Fri 24 May 13 19:17
» Jokes - May '13 by C6NL on Fri 24 May 13 16:05
» American Car Speedfest on Sunday 9th June 2013 at Brands Hatch by Red Coyote on Fri 24 May 13 15:44
» Air filter assembly 1991 L98 in Spain by bigredmachine on Fri 24 May 13 13:05
» 2013 CCCUK Race Series by aaroncorvette on Fri 24 May 13 12:20
» C3 (and other generation) parts for sale by Mightygeorge on Fri 24 May 13 12:17
» TH350 Tranny by wev on Fri 24 May 13 11:03
» Expansion tank cap - don't suppose anyone has one? by aaroncorvette on Thu 23 May 13 20:42
» Opie Oils 25% Off Everything - Code MAYHEM by oilman on Thu 23 May 13 13:16
» 11-12 May 2013 Italy Garda Lake International Meeting PROGRAM by chevykevv on Wed 22 May 13 20:14
» My in car gadgets by Firepit on Wed 22 May 13 13:43
» C5 Transformation Underway by craigyboy on Wed 22 May 13 13:20
» Engine stumbles and dies at junctions, in traffic etc. - Help by wofforduk on Wed 22 May 13 10:47
» Le-Mans 24 hours 2013 by maxuk1981 on Wed 22 May 13 07:38
» For Sale C3 Car Cover / C5 Magnesium Wheels with bridgestones by dex99 on Tue 21 May 13 22:37
» Rolling Road by Al Mundo on Tue 21 May 13 22:18
» Swiss vette club video by Gixer on Tue 21 May 13 21:57
» High oil temperature and pressure by Pigginvet on Tue 21 May 13 17:30
» New C4 purchase by nickjames on Mon 20 May 13 19:58
» That time of the year... by kentvette on Mon 20 May 13 09:55
Tyre pressures
Reply to topic
Author
Message
Josh
Future club member?
Sat 04 Oct 08 13:58
Tyre pressures
Anyone know if there is a formula or some kind of calculation for working out what the air pressures should be on non-standard size wheels/tyres? Or would pressures remain the same as standard due to the cars body weight obviously not changing?
I have 275/40-18 rear and 245/40-18 front and don’t much fancy the idea of waiting to see if it’s the middle or the outside of the treads that wear out first just to establish over/under inflation!
Any ideas?
Thanks.
c5ynk
Club Member
Sat 04 Oct 08 14:28
Hi Josh, they are similar size tyres to my c5 i run 30 on front & 28 rear because i was finding the rears were wearing in the middle to much hope that gives you some help MICK .
Hi,im MICK when i was 21 i owned a 1976 t top red white leather owned it 4 years at about 12,000 miles a year had some great fun.Move on 28 years and wife, house,kids,now i have a toy again a red c5 2002 reg C5 YNK,love it RED interior 40,000 miles ,hoping to have just as much fun again on 7,500 miles policy
Josh
Future club member?
Sat 04 Oct 08 18:33
c5ynk wrote (View Post):Hi Josh, they are similar size tyres to my c5 i run 30 on front & 28 rear because i was finding the rears were wearing in the middle to much hope that gives you some help MICK .
Hello Mick and many thanks for that info.
I'm currently running 30f/30r (as it was when I bought it). It's difficult to judge where the wear is until they are well gone, but I think I'm getting more 'edge' wear (both edges even, so alignment is ok) than middle. Think I better find a calibrated pressure gauge or compare mine to a known good source.
Cheers.
roscobbc
Regional Rep
Sat 04 Oct 08 18:53
Josh wrote (View Post):c5ynk wrote (View Post):Hi Josh, they are similar size tyres to my c5 i run 30 on front & 28 rear because i was finding the rears were wearing in the middle to much hope that gives you some help MICK .
Cheers.
When I bought my 18"s for my C3 from North Hants Tyres I asked this very question and was told 2 psi per extra 1" of diameter - in my case now 31 psi. This seems fine but as was said I'll only really know about eveness of tyre wear when they are fully worn out!
'68 coupe - 4 speed - 3.08 - F41 - 489 cu in - 528 bhp @ 5850 rpm - 565 ft/lbs torque (766 Newton Metres) @ 3850 rpm - (225 bhp & 465 ft/lb Torque @ 2500 rpm)
Act like a juvenile before turning senile !
Josh
Future club member?
Sat 04 Oct 08 19:04
roscobbc wrote (View Post):
Thanks Roscobbc,
Gotta say it confuses me. 18's have possibly less volume than 17's because of lower profile (dunno). Then there is increased width which increases the volume. I'm stumped at what's best, but the trial and error is bloomin expensive way of finding out! Sad
Cheers.
roscobbc
Regional Rep
Sun 05 Oct 08 02:26
Re: Tyre pressures
I found that my old Goodrich 235/60/15 on 8" rims would scream like a 'stuck pig' going round corners at anything approaching a reasonable speed. I tried 35 psi, then 32, 30 which stopped the squeeling but one could sense that the shockers were not dealing with it and the tyres would skip and patter on poor surfaces. 28 psi seemed a happy medium. It seems as though a number current cars with low profile tyres have higher manufacturer reccomended pressures.
Josh
Future club member?
Sun 05 Oct 08 12:25
Thanks again roscobbc.
Yes a good point that perfomance needs considering as well as wear. I'll have to experiment and hope the two are compatible!.
Many thanks
VetteG
Club Member
Mon 06 Oct 08 07:46
Re: Tyre pressures
I usually run my 18" at 28 all round, not sure why peeps are using a higher pressure in the front since weight distribution (with a small block) is almost 50/50 front/rear Scratchchin
G
1970 Small Block Coupe, 450hp Motor, March Pulleys, twin spall fans on aluminium radiator, Steeroids, Tremec T56 6 speed c/r box, Smart Struts, Sports Rotors, Hydroboost, Semi Coil over front suspension and alloy upper control arms, 18" Alloy Replica Rallye Wheels 8" front 9 1/2" rear with Pirelli Pzero's. www.graemeinglis.com
FranV8
Club Member
Mon 06 Oct 08 19:22
I think it's an experimental job. You are supposed to be able to do it with a thermo gun or tyre pyrometer (thermometer basically) and aim to get an even spread across the whole tyre, however I think it's a suck it and see (try different pressures and see how you get on). It will vary by tyre construction as to what's the optimum, as well as tyre and wheel size.
Wear pattern is also a good one, but I can see that in some cases this may only achieve even tyre wear and not necessarily any other benefit.
1995 Corvette LT1 6-Speed Coupe
1990 Japanese thingy (MX5)
2007 Honda UFO
Previous
1986 Corvette Z51 Coupe
Josh
Future club member?
Mon 06 Oct 08 21:25
FranV8 wrote (View Post):I think it's an experimental job.
I fear your right, only hoping it doesn't take too many sets of tyres and the demise of my bank balance.
FranV8 wrote (View Post): You are supposed to be able to do it with a thermo gun or tyre pyrometer (thermometer basically) and aim to get an even spread across the whole tyre,
That's intereting... I've never heard of that method. I wonder if it makes any difference because my tyres have been inflated with a Nitrogen! mix... from what I'm told it's supposed to be less sensitive to pressure variations due to heat. More likely just the tyre fitters way of charging me 12 euro's to pump my tyres Rolling Eyes ... I dunno!
Reply to topic
Permissions
