Steering coupling joint rebuild - you can do it!
Author |
Message |
Future club member? |
Sat 26 Sep 09 19:53 Steering coupling joint rebuild - you can do it! I decided to put this in the tech section in case it was useful to others, but its part of my overall restoration project, generally.
Sat 26 Sep 09 20:00 Re: Steering coupling joint rebuild - you can do it! The kits come with a whole load of tosh, most of which is only good for your spare nuts and bolts tin !!
Sat 26 Sep 09 20:07 Re: Steering coupling joint rebuild - you can do it! Starting with the small half of the joint, fit the spline pin into the side where the pinch bolt enters. The small flush head leaves clearance for your socket doing up the pinch bolt! You could fit the other pin in the kit which bolts on but you will have to use a spanner on the pinch bolt as the nut will be right in the way!
Sat 26 Sep 09 20:18 Re: Steering coupling joint rebuild - you can do it! Place the disc on the flange and fit the collar nut on the spline pin and the normal nut on the medium pin. I could not seem to get a washer on as the disc was a bit 'fat'. I'm not fussed. It's done up tight against the shoulder and is cover by a brace later so it cant come off. You can always add some loctite if you want.
Mon 28 Sep 09 21:35 Re: Steering coupling joint rebuild - you can do it! good work - I just did mine 3 weeks ago as I needed to reconnect the steering to move the car out of the garage.
Mon 28 Sep 09 22:30 Re: Steering coupling joint rebuild - you can do it! Glad to see that someone else had a stab at this.
Tue 29 Sep 09 23:50 Re: Steering coupling joint rebuild - you can do it! Ah, yes if you have a sheet like that it would be great! But I am wondering if maybe there is any difference between the later post '77 cars like yours and mine where the column, dash and bulkhead are concerned?
Wed 30 Sep 09 18:02 Re: Steering coupling joint rebuild - you can do it! Well I guess things do vary slightly but I expect the procedure is similar. I mean it still has all the generic parts, Box, Joint, Column bracket, Column. send an email to jon @ firstpowerservices.com and I can fire it off by return.
