'86 Starter Issue
Z06George
So I took the car for the weekly shop and it ran perfectly fine until I tried to start it again to come back. Electrics working fine. Left it a bit longer and still nothing so rang the AA, of course when he arrived it started again with a bit of throttle. Reading online it could probably partly be heat soak but he was fairly insistent that the starter is on its way out.
Before I ring Topcats to put a new starter in. Is it worth trying to do anything with regards to heat soak or is it even possible to do a starter replacement at home?
TIA George
If the Starter is damaged due to Heat Up issues, too late if you want trouble free.
If damaged install a new Starter Motor and an Aluminium Heat Shield to reduce some of the heat transmitted from the Headers to the Solenoid - do not use a Heat Blanket
not all aftermarket Starter Motors are the same, some have the electrical connections on the Solenoid better placed to be further away from the heat source - The Heat Shield is important
