Hi all, nearly ready to get the gearbox issue sorted, have new bolts for bearing support and complete muncie rebuild kit so ready for anything found. I wonder if anyone could write from experience a step by step procedure for removing either just gearbox, or engine and box together.
including what needs to com out of the interior etc to remove shifter etc .
I have a reverse lock out cable too.
I read somewhere about a certain sized bit of wood to put between motor and bulkhead when lowering back of motor to get box out. Some say bellhousing stays attached to box , others seperate and just pull box .
any advice very welcome. Want to send the box to clive the muncie specialist , pro build american in norfolkTiA
