I would say definitely worth a look . OK so its not original spec but it depends what your requirements are . There must be a lot of modded C3`s out there and it looks a nice example on the face of it . Candy Apple Red will be a custom job respray it that was a fave colour with the Hot Rodders and really ` pops` in the sun and looks well with period style Craeger Mag wheels . Interior looks nice and almost certainly an after market upgrade but compliments the exterior . Check thosethoseJust be sure to check out all potential trouble spots we have already identified . Make sure the `bird cage ` is sound and no rot causing flexing which might have caused windscreen crack . If car sound at least use getting the windscreen replaced as a bargaining point as it won`t be cheap
I run an Edelbrock Torker 2 in my car which has a replacement Camaro IROC -Z higher compression engine coupled with a Holley 750 cfm 4 Barrel Double Pumper with vacuum secondaries without problems . It just needs to be given some beans a bit to reduce bog down as it`s street performance set up that needs some revs . Just adds to the fun
. As Rosscobc said , the Torker 2 is a single plain inlet manifold and is a performance mod for a wide range of V8`s for street use with limited hood clearance . It gives a flatter peak torque curve than standard thus giving maximum torque for a longer period in the engine revs range before the inevitable power `drop off` occours . It`s the torque that gives the best accelleration , not the bhp . Side pipes will be loud especially exiting right by yer earhole !! Check those lower control arm mount brackets I mentioned before for cracks at the weld joint to chassis cross member . I have attached a photo of mine now double welded for extra strength . You will see them by peering down in between engine a rad but drivers side one more difficult to see as power steering pump in the way . Best seen from underneath with car on a lift.
View attachment 6738View attachment 6738View attachment 6739
