Anyone know this C3?
Z06George
Hi all,
New to the forum but a long time enthusiast.
Looking to buy my first Corvette and I've found this one. It's limited on pictures and the seller recommended a viewing instead. However I'm away with work for a fortnight, so I was wondering if anyone here knew the car or if there's anything specific to the C3 I need to look out for?
Thanks in advance,
George
Rich
George, I have emailed you a copy of the CCCUK C3 Buyers Guide. Hope it's of some use.
Good luck with your search and finally you may be on the verge of Corvette ownership.
Hidden areas - Look for Rust to Birdcage and Windscreen Frame, need to remove side Trim to both footwells and interior Trim to Windscreen frame, top and sides - look for water damage to carpets (under feet area) possible tell tale of leak from area surrounding the Windscreen
Front offside wheel looks a little to the back in the pic - could be angle of the wheel in the pic - could be shimmed wrong re caster or could be tell tale of a knock - often just bad adjustment to caster.
Best of Luck - which part of the Country are you in ?
