BS, Dyno Thoughts & HP Losses
Chassis dyno are great tuning aids, but they only give an approximation of power output, as some important variables are not accurately controlled. Certain magazines seem to think that results obtained from chassis dyno are the gospel.
They are not. In one recent independent test, hp figures varied by 11% simply by doing the runs in different gears and in another test, results varied by almost 4 % by doing the runs with a different wheel/tire combination. Tire alignment has been shown to affect results up to 3% as well.
Note that Engine hp DID NOT change here yet the dyno recorded an increase in hp at the wheels. A change in wheels/tires also does not affect true, wheel hp either, only the rate of change on the rollers and the vehicle acceleration on the road. One can only conclude that inaccurate moments of inertia and correction factors are being used.
On intercooled, turbocars, there is usually insufficient airflow to ensure accurate results due to charge temperature variation, which can be substantial. Even coolant temperatures may not stay down during the run, which can affect power outputs considerably.
The rate of acceleration is also important on turbocars to be sure that the boost is not lagging the engine rpm. With RPM climbing too quickly, the boost has not reached a peak value, so the hp figure is again inaccurate. Turbocars should therefore be tested in top gear.
Without proper temperature stability and accurate moments of inertia on the rotating components, there CANNOT be accurate results as the scientific method is no longer being applied.
When all things are kept the same between runs, and you get a tangible gain, it is a gain at least. How much, is open for discussion. It is important to note that as the oil temperatures in the engine, transmission and differential increase, friction usually decreases. This manifests itself as an increase in power at the rollers on each subsequent test.
This factor should be accounted for when doing back to back runs. It may look like you are gaining some power on each run by making other changes, when in fact this is due to reduced oil viscosity.
When using a chassis dyno, always use the same gear and tires and wheels and start the runs from the same speed or RPM. Re-baseline periodically to see what temperature increases have done to power output.
Chassis dynos are quick and easy to hook up but have many of the above failings. They do not possess the accuracy of a properly calibrated engine dyno which has a more carefully controlled environment and condition set.
Obviously, most non-professionals don't want to be yanking engines to use an engine dyno so chassis dynos do have their place.
Flywheel vs. Wheel HP
As most people know, there are power losses through the drivetrain, so wheel hp is always lower than flywheel hp. Front-wheel drive cars with transverse engines tend to be more efficient than most rear drive configurations due to the layout of components.
However, most publications overestimate these losses considerably.
Most rear drive cars have a 1 to 1, 4th gear which means that the power path goes directly through the main shaft of the transmission.
The only losses here are bearing drag which is less than 0.5% and the viscous drag of the gears running through the oil which is about 1% with hot oil. Indeed, published data indicates a transmission efficiency of 98 to 98.5% for conventional transmissions in 4th gear.
Losses within the driveshaft account for about 0.5% if they are properly aligned, balanced and with fresh U-joints.
Differential losses in the commonly used Hypoid type gearset is in the order of 6 to 10%.
The worst scenario case for a rear drive setup is on the order of 12.5% in 4th gear, not the 20 -25% often published. If 25% was being lost in the drivetrain, the oil would boil in the differential housing in short order and aluminum transmission cases would fatigue and break from the temperatures generated.
On a 200 hp engine, something on the order of 37,000 watts would have to be dissipated out of the transmission and differential housings. Obviously, this is not the case.
Transverse, front drive transaxles usually have no direct lockup gears and no 1 to 1 ratio, however, since the torque path is never turned 90 degrees as in the rear drive setup and efficient helical gears are usually employed for the final drive set, losses are more on the order of 6 to 9 percent in the upper ratios.
Tire pressure and wheel alignment can have very significant effects on losses at the rollers. Tire pressures should be set the same between each test.
Tire rolling resistance varies inversely with speed, another factor not taken into account by most chassis dynos when applying phantom flywheel hp formulas.
Comparing the Numbers
Many novices are quick to compare hp numbers between chassis and engine dynos and come up with all sorts of wild conclusions about drivetrain losses. These comparisons are essentially meaningless. Inertial dynos are based on the sound scientific principle of accelerating a certain mass with a known moment(distance) over a given time.
The rate of acceleration of that mass and moment is a result of the force applied (torque). If the RPM is known, HP can be calculated. On an inertial chassis dyno, it is virtually impossible to calculate the the moment of inertia of every tire, wheel, gear, joint , axle and shaft in the power train between the crankshaft and roller, therefore its results cannot offer an accurate HP figure.
Even with coast down drag measurements, these cannot be accurately calculated as different factors are affected in different ways. Some are proportional, some are inverse squared functions etc. Inertial engine dynos offer a very accurate figure if properly calibrated, as only the flywheel's moment of inertia needs to be calculated and added to that of the billet. Water brake or eddy current dynos generally measure force (torque) directly through a ram or strain gauge, so moments of inertia are not important on these in fully loaded tests.
Concluding that there was a 25% drivetrain loss by comparing HP achieved on an inertial chassis dyno and that obtained on an engine dyno is fundamentally flawed, in that the chassis dyno numbers are highly suspect in the first place.
Other things to watch are correction factors applied for altitude, barometric pressure and temperature.
These factors are NOT the same for atmo and turbo engines. Using atmo factors inflates the true, corrected HP figures on a turbo engine. In fact, look at the correction factor applied on your dyno sheets and see if they make sense.
Many shady dyno operators simply enter a phantom correction factor to make the customer happy.
This is a case where the dyno sheet DOES lie. Chassis dynos are essentially for tuning purposes, they are not well suited to giving an accurate hp figure.
Be aware that SAE correction factors do not apply to turbocharged engines!
If your dyno sheet lists SAE corrected HP, ignore it as it is incorrect.
You are better off getting an idea of where you stand by looking at observed hp with a turbo engine.
One of my customers recently received a well known commercially available chassis dyno with both inertial and eddy current loading capability.
When a different vehicle weight is entered in the software for a pull, the computer spits out a dyno sheet with vastly different hp figures.
This is complete BS and shows that the software package is just plain wrong. HP did NOT change on the pull simply because a different weight was plugged into the computer. Take all these figures with a grain of salt.
I had an engineer from this company E-mail me and tell me their dyno were accurate.
I told him I'd be happy to look at his data and asked him to send me his information to support this claim. I never heard back.
Changing the weight DOES NOT change the hp the engine puts out PERIOD!
Another SDS customer had his drag car chassis dynoed. It showed a max hp of 280 yet when the car weight, ET and trap speed were plugged in, these showed that around 500hp was required to achieve these results.
The dyno figure was so far off, it was essentially useless.
Looking at the jagged, sawtooth "curve" that most chassis dynos produce is amusing.
The torque and hp curves really don't look like this. This is a result of poor software or mechanical measurement in the first place. Torque does not go up down, up down 2-4 ft./lbs. over 50-100 rpm, as any real engine dyno will prove.
Chassis dynos are essentially tuning aids, not true hp measurement devices.
Use them to dial in your EMS mapping, not to brag to your friend's that you made XXX hp.
When he blows you away at the stoplight, you'll just look, just, well, uninformed.
