Thanks for this. As a definite NON-electrician I've been learning and feeling my way around this issue. I've cleaned SP122, G401 and G105 (although the way the car is up on blocks at the moment I can't reach the block end of that one yet) . All were in good condition but I cleaned them anyway. I also took the front right wheelarch cover off and disconnected the large multi-plugs on the PCM. I didn't do any checking but they looked in good condition, no sign of the corrosion I've seen in some pics.
As background, the reason for doing all this was because the fuel pump wasn't working. I'd been advised it was probably the pump so took the tank out (this C5 has the later FFS fuel system so pump is mounted on top of the tank - not an easy job!). I connected the pump directly to the battery and it worked. I then re-connected it to the loom, took the relay out and bridged terminals 87 and 30 and the pump ran. I then went through cleaning all the grounds as above, tested the control side of the relay (T85 and 86), had a test light come on for the 2 seconds but when I reconnected the relay it still didn't work.
I had already tried swapping the relay for the horn relay and thought it had worked, but only temporarily. I tried it twice and the pump ran for 2 seconds, came in, washed my hands, went out and tried it again but it wasn't working. Stumped, I then read up on testing the relay itself. I activated the switch and the resistance was very low so I thought it was OK. That was when I thought maybe the terminals that the relay fits in may have opened up so I tried to separate the fuse/relay board and posted the question.
Today I put everything back together, bridged T87 and 30 to confirm the pump ran, tried the relay again but still no go. This time I heard the relay click so I knew it was switching, but it clearly wasn't putting the power out. This time I tried the relay from the a/c and it worked!!! I've now tried this more than a dozen times and the pump runs for 2 seconds every time.
So, it appears to be the relay but I'm not sure if there is something that's causing the relay to fail. The horn relay now doesn't operate the horn. It clicks and if I tap it the horn works but only temporarily. I had also used the fog-light relays but they didn't activate the pump and if I put them in the horn position they don't operate the horn either. Seems I need 4 new relays and that's probably more than a coincidence. (I can't vouch for the fog-light relays to have been in working condition as I can't remember the last time I used them).
I would still like to take the fuse/relay board apart if possible, just for peace of mind, so if you can help with this, or have any other ideas, I'd be grateful.
Hope all is well with you and yours in this lockdown. How are things in Norway?
