Good luck .Great stuff I've got some help tomorrow' to check (wheelchair bound)
Doesn't the '81 have an electronic 'emissions' carb with all sorts of weird stuff connected to it?
Have you had the spark plugs out to see what condition they are in ?Looks like this could be it,a countersunk screw? However on start up it sometimes struggles, fluffs up and emits a lot of smut out the back like the choke isn't working properly,any advice on how to adjust them and would this contribute to the problems?
Edit, not sure if files uploading
Yes they're fouled up, ive renewed them but they foul again because this richnessHave you had the spark plugs out to see what condition they are in ?
I always cringe when I hear " one year only " ! Hope it turns out be an easy fix .I suggest you read this thread from the US forum. Looks like an 81 has a one year only carb with electronic mixture control.
Where are the air/fuel mix screws on the '81 - CorvetteForum - Chevrolet Corvette Forum Discussion
Thank you, i played around with the choke mechanism and sprayed it and it fired up and ran great, it drives fine, just smells rich,looking at the plugs again, yes they're fouled but when i say that they're well within usable realms, the thing is that the car doesn't run for months at a time,I suggest you read this thread from the US forum. Looks like an 81 has a one year only carb with electronic mixture control.
Thank you, the do sell a tool for these carbs that seems to be for it, maybe it will work, I'll try it, I cant load pictures up for some reason,I suggest you read this thread from the US forum. Looks like an 81 has a one year only carb with electronic mixture control.
I cringe a lot as I own a '68.....I always cringe when I hear " one year only " ! Hope it turns out be an easy fix .
