Connector for Nailhead Temp Sender
Vetman
Looking for the electrical connector for temp sender with nailhead connector, similar to this photo. Any local suggestions?
CK supply the the connector and lead insulation together - see here. Expensive if all you want is the connector. I'd have thought it could be relatively easy to modify an appropriately sized female Lucar connector....
....to do the job?
That is what I did . Found the correct size female spade connector and remade the existing cable into that . Cheep as chips and works perfectly . (y)
Vetman
Thanks. I have done this and it works but a bit loose so hoped to get the proper fitting, but reluctant to pay to have a GM one sent over.
If you nip up the spade connector with a pair of pliers you should be able to make a tight fit . I managed to retain the original plastic insulator cover to slide over the spade connector to protect it too .
