Door removal on 79 coupe
Nigel curry
Hi all
Anyone had any experience on removing doors on my 79 coupe!i have removed the door panel to tighten the mirror but I now want to remove the door completely
Any thoughts would be most welcome
Regards nige
Nigel curry
Hi all
Regards nige
Sorry All.having read my original message it sounds wrong!! I meant has anyone had to remove the doors on A 79 coupe!! Not MY 79 coupe (if you know what I mean) rambling old git.
Nige
Custom exotics
Nige
If you have door panel removed its fairly simple remove top cover plate to reveal the 4x 9/16 bolts and you should be able to see 4 more through bottom hole disconect wiring in door from elec windows and central lockingi f you have it pull grommet from door end then u will need help from a mate as doors are heavy one hold door one undo all the 8 bolts and just slide door off hinge feding wiring out as you do ....simples...
Nigel,
I found that getting the wires out was a bit tricky, especially if you are doing it on your own. Would be best to have an assistant.
