I’ve just retro fitted the original spindle and drum brake to the front of my 63, it had discs upfront which as we know may stop the car but not year correct. Some of you will remember me posting about the front spring install procedure before but I will show it again as I can’t believe how quick and easy it is.
You will need this type of spring compressor from ebay or the like circa £20 a pair although you only use 1.
Next remove shock absorber and drop the threaded part of clamp through the upper shocker hole in frame with a large washer on with grease.
Slip the clamp levers up through the lower A arm shocker hole and screw the thread to it. Make sure the slightly longer clamp leveris to outside of car. Now with either an air gun,.socket set or lengthy 3/4” spanner (spanner will make you warm) start tightening up the thread until spring is released from lower a arm. At this point the spring is tightly clamped up to frame cup. The ball joints can now be separated from the spindle upright. Hinge the lower a arm down, unscrew thread and spring is out. Install is the reverse procedure. upright out and upright in took me 30 minutes a side with no issues, all relaxed (for a change).
