Alan Collins
Hi, thanks to all the club members for their help on my recent calliper issue.
I was reading posts and came across a comment that rivets showing through the front panel between bonnet and lights is a sign of corrossion of the head light support member. I have the above symptoms and was worried what I might find the next morning. Relieved to report that the support member is sound. I purchased the car knowing the previous owner had imported it with minor accident panel damage to the front passenger corner. A repair had been carried out by a "specialist" UK bodyshop and the owner had done a respray. I suspected there may be trouble lurking under the fresh paint so negotiated a price allowing for body works and a proper respray. I have used the car for 3,000 miles and let the bodywork settle, I now have cracks around the head lights and rivet heads showing where the support member is attached. My questions are:
1) Should there be a support rod running from each side of the support member to a point on the chassis below each end of the radiator. If these are missing this would explain my problems as the body will be flexing and then cracking. I can see one central support rod only, shown in the attached photo. Please can anyone advise what support sytem should be present and if possible post photo(s).
2) I have read that the support member should be bonded in place with a two part epoxy panel adhesive, not riveted. How should the member be fitted and should I drill out the rivets remove the support panel and refit with panel adhesive.
