Mike
Hi there other members !
I’m afraid I’m not very technical so hopefully someone else who is might be able to guide me in the right direction.…
I noticed the other day that I appear to have ‘deformed’ my passenger side rear panel, just under the bumper, per the attached photos (I’ve also scratched the panel but that will be a fairly quick fix hopefully), as I was reversing into my garage.
My question is….is this because of some material on the inside of the bumper that’s designed to deform on a low speed impact (as my Regional Rep, Gary, suggested when I asked him but also suggested I ask my fellow members, hence my post), and would I be able to see it if i jack it up ?
my next question is, is this a ‘self fix’ or will I need to take it in to be repaired because it needs new material behind the bumper (in which case I was intending to take it to Autopics, not far from me in Worthing, West Sussex, as I think the gaffer there is a member here as well.
and finally, I have been thinking about replacing the exhaust with either a Magnaflow or Borla system in order to try and get a ‘V8 rumble’ from it, as my straight through system sounds a bit ‘weedy’, or am I expecting too much ?
cheers
Mike
cheers
Mike
