knock offs that wont knock off
8 Pot
i have one of those german tool thngs attached to a torque wrench attached to a scaffold pole and no joy. i have tried the lead mallet thing. no joy. i just get them loose so i cant change the tyres. anyone got any tips
Are you turning them the correct way?
Use a bigger hammer. Thor Hammer, still made in the West Mids are the tool of choice
8 Pot
yes they have the direction on them. it might be i need a much bigger hammer to make an impact i dont know.
8 Pot
i cant see any pins at all. i had read about those but i cant see any. not sure where i am looking though
Corvette
Ditto Oneball‘s comments. They normally come off when you drive 🤣. You’re not whacking the end of the ear hard enough with wheel on the ground.
You can see the grooves I marked in the image for where a pin would slide in are not aligned, so there is none installed
Looks like rusted, As mentioned need to spray that would break down that rust
Else may need to use heat on the spammer, so it expands a bit and then try to get it off
8 Pot
i have just loaded it up with WD40 (other brands are available) and will see if that makes a difference. i will see if i can get a bigger hammer....
Don't be afraid to beat the hell out of them (in the right direction of course!) Order some replacement security pins from CK
Chris is one of the most helpful members you could meet so I know he'll be fine with me posting the attached tutorial
  • Changing Knock-Offs.pdf
I think it’s usually a 5lb hammer, just give them a wack. Original knock offs do not have safety pins, if no pins on repro wheels , they must just be stuck. A good few racks and a little wiggle and they should spin off. Nothing else is holding them on
Makes me wonder why GM called them “quick take off wheels”
