Jimbo64
MoT advisory on steering idler arm resulted in me purchasing a new one, with grease nipples.
Given that maintenance manual states just to keep wheels off ground, keep them straight and then a simple unbolt and replace unit, quite happy to do this myself.
Old unit came out easy enough, few taps to get tapered portion out. Tried to fit new one and wasn't fitting at all well. Check of old against new, showed old's arm to bodywork, at an angle, not straight like new one, albeit this is the part that had the movement in the bush that Tester recorded as advisory. The base of this arm on old one also very flat, almost concave, allowing better fitment at chassis. New one's casting is far more convex. See photos to clarify what I mean.
So my queries are this;
1. Should I fit new arm as is, or try and move top arm?
2. Should I grind convex part of arm to allow fitment?
Or maybe I should just call in a friend and utilise a second pair of hands to assist with fitment and this will prevent any of the above?
Cheers, Jim G
Cheers, Jim G
