trevbeadle
I'm trying to get the horns to work! I know they are problematic on the 'vette. I've deduced the horns are operative. Applying 12v direct to the horns, they work! The upper contact on the spring in the centre of the steering wheel has constant 12v regardless of the position of the ignition switch. ? Is the normal that the horns will normally work with ignition off? I've cleaned up the push switch and reassembled, nothing broken and constant 12v to the horn push ring with the 'L' bracket that contacts the upper contact plunger/spring! I've seen 2 ways of assembling the horn push, one with the bottom mounting ring with the 3 screw lugs under the tilt locking ring (Pic 1, uTube) or above it, but the other way up? ( as my original Pic 2). Grounding the horn ring with a screwdriver gets a few electric sparks but no sound from the horns!
I deduce it may be the horn relay....but can I find it!! No............It is not under the bonnet and I cannot find anything that resembles it under the dash and above the fusebox! (Pic3) ( as an aside, the only green and red wires I can see are those on the RHS of the pic but the 2 pin connector plug is not connected!! ) HELP!
