Last triumph
I'm making some fine adjustments to my door and need to loosen all the hinge bolts with the 9/16 heads within the door.
I've got the door panel off and the bottom ones are easy to access and undo, as a socket slides straight on to all four, however the upper four bolts behind the little access cover is a different matter. The rear most two are fine, the socket slides straight on, however the front most two have partially hindered access due to the door pressing - you can't get a socket on it straight.
There's not enough room to get a spanner in there so I must be missing the obvious technique to access these bolts.... what's the tool/technique?
