If it is a standard rear spring the longer lowering bolts should do it - remember if the front springs are down that will raise the back and vice versa - a composite spring is going to need shocks to suit.My 71 is almost 2 inches higher than it should be at the back due to the aftermarket steel spring the previous owner fitted, apparently a fibreglass one will bring it back down again. Would also like a pair of 8 inch lowering bolts.
I’ve got a used standard steel one if you want it. I’m in Worcester.
Mine was sitting like this with it on.
Appreciate the offer as your car looks to sit perfectly but i'm not sure if leaf springs wear out and it will negate any benefits from the completely overhauled suspension....
Not necessarily. I’ve seen cars sitting too high with a glass spring. There’s other factors besides the important poundage rating of the spring. Wheel camber will make a difference, as does tyre pressure on deep section tyres. Tyre diameter will vary depending on what size tyres you have, all can make a difference to the ride height. Gas shocks do actually hold the car up slightly too I’ve found.apparently a fibreglass one will bring it back down again
And of course not all springs are created alike - differing poundage of springs, OEM original steel, OEM replacement 'glass, Aftermarket steel, Aftermarket 'glass - too many variables - heard of too many issues not to be vary careful with 'glass springs (they have been known to de-laminate) - I'd be concerned about too much reliance on 'lowering bolts' and consequent reduction of suspension travel........Not necessarily. I’ve seen cars sitting too high with a glass spring. There’s other factors besides the important poundage rating of the spring. Wheel camber will make a difference, as does tyre pressure on deep section tyres. Tyre diameter will vary depending on what size tyres you have, all can make a difference to the ride height. Gas shocks do actually hold the car up slightly too I’ve found.
My car is set low at 27 1/4 inches to wheel arch with a steel spring.
From the Pic not too easy to see but front is down which would send back up - Single adjust shocks on the front Coil Overs is good - I would not bother with a Composite on the rear, plus you have just put new Shocks on the rear that most likely are not a match for a Composite - Rear Steel Spring is Ballast - Not the best place to remove weight - If anything Heavy Duty Steel rear Spring and Single adjust Shocks.I think this picture shows my issue quite well, the rear of the car is just way too high and even with the new wheels on it's too big of a gap to accurately place the fender flares. Have decided to go for a coil over kit on the front as I think the old springs have had it (driver side is an inch lower than passenger) I'm going to try the used spring offered above and see if that at least gets the car sitting right to get the flares fitted. Would like to do a rear coil over conversion but theres only so much money i'm willing to throw at this money pit.
Dazaa, I have just clicked on the small image and now looking at the bigger picture, I correct myself, the front is not unduly low, presuming your issue with excess body height at the rear is the same on both sides of the car a new correct steel spring will sort it, but remember you said you had a bad front spring, well that would normally send the front down on that side and the back up on the other side, so to square up the car you will also need the new front springs in place at the time.
With the Coilovers at the front you will be able to adjust the ride height at each Coil independently irrespective of the rear - get single adjust shocks same on the back and you will then have a Vette with fully adjustable suspension, ride height, hardness and everything else. (Twin adjust Shocks at the Rear if a Composite - but I would not want to go there)
Where are you based?
Why are you not a Member of the Club?
Dazza - Essex region meet Margaretting, not too far if you are based in the 'eastern' part of east London (like me). Some of the insurers will demand being a club member - you'll normally get a discount. You'll also get a club discount from some suppliers. Customville is one to try in your area.
