Wanted: Quiet exhaust! (Swap)
Mike-
Hi
Currently have a Borla exhaust on my C5, unsure of the model but it’s the one with very small silencers just before the tips. Long shot but if anyone is up for a swap with a quieter but still aftermarket exhaust give me a shout. It isn’t to my taste being so loud and I do quite long journeys.
cheers
mike
Alexm
Hi
cheers
mike
Hi Mike
I have in my garage a standard c5 axle back exhaust system(opposite to your self swopped for a Borla system).
Owned by a mate of mine (the good elf) on here.
I think he wants £ 150 for it.?
I also have a C6 exhaust system (cat back) has had slight mod to final chambers to make slightly louder ( but wasn’t enough for me, so a borla fitted.4826
Mike W
Busy user
Hi Mike,
where are you located? I could be interested in a swap. Mine has an aftermarket system but it's not very loud.
I'd be interested if you're not too far away. I'm in Somerset.
Mike-
Should’ve probably mentioned earlier, I’m in Yorkshire so prob a bit far. If you’re ever passing through though let me know.
Robert Craske
Hi Mike
I also have a C6 exhaust system (cat back) has had slight mod to final chambers to make slightly louder ( but wasn’t enough for me, so a borla fitted.View attachment 4826
I would be interested in these if they are still available and depending on where you are in the UK.
Alexm
Hi Robert
Based in kent Bexleyheath area.
Are you interested in the c5 or C6 bits?
I have some new pics of both now if interested?
Alexm
The C5 exhausts for £150 and what C6 bits do you have as I have both a C5 and C6.
Hi Robert
Have C6 cat back system with mods to outlet chamber, basically a hole in out side of box with a removable cover, internally a 30mm hole drilled through the inlet pipe so bypasses the acoustic part of the silencer.
Is louder than standard but not by mega amount.
Robert Craske
Hi Robert
Hi Robert
Robert Craske
I dont know when i can pick them up with the lock down but I can transfer you the money for them. Do you mind holding onto them for me as it maybe a month or so or much more ?
Alexm
Robert
No problem to hang on to them (can’t go anywhere anyway)
Let’s hope things get sorted sooner rather than later, and you can pick up when ready.
Will need a days notice for collection as they are in my mate Andys garage (who owns them)
Contact 07939 083149 when ready
Regards
Alex
