Paul Benton
I wondered if anyone has had this issue and has a solution to this puzzle.
When the wiper switch in the center console is operated I can hear a click from the wiper motor/solenoid when it is pushed in for the washer and when the switch is moved to operate the wipers but the motor doe not operate. However if I use the second switch under the steering column the motor turns and the wipers can be switch on and off using it.
Before I pull the wiper motor any suggestions would be very welcome?
Stay safe and well
Paul
Stay safe and well
Paul
