C7 2017 Grandsport Diff oil
Referring to your owner's manual and having a GS with the eLSD you need to use GM's recommended fluid
that meets Dexron-VI makeup
There is the rear axle fluid (that uses ACDelco 10-4034 Dexron LS 75W-90 Gear Oil [88862624]) and
the eLSD (that uses ACDelco 10-9394 Dexron VI Automatic Transmission Fluid [88865601].
Mobil I sell both in synthetic versions,
I have used the transaxle version for years in the diff of my 99 C5 and also the Dexron ATF version in the manual tranny
Digger John
Have tried finding the
Mobil 1™ Syn Gear Lube LS 75W-90 no one sells it in the uk. unless u buy 20ltrs​
