Jimbo64
Folks, rather than lying around in my garage, hopefully someone can get the use of either/both of these.
I have my original (well it was on my car when I bought it!) air filter housing. For original Rochester carb etc that was on my 1972 C3 smallblock auto. By no means perfect, but certainly useable. See photos.
C3 smallblock radiator, for a manual (so no use to me). Appears to be a Harrison make? I've just had a radiator specialist friend, resolder the inlet and outlet pipes and the expansion pipe at the filler neck. The drain plug was just a stripped bolt pushed in! so that's been changed and sorted too. He then pressure tested the radiator to 20 lbs/psi and all good. It is a four core unit, so should be pretty good.
See photos
See photos
