Fatbloke-Dim
Busy user
Anyone have any experience of a readily available, in the U.K.,code reader/scanner? Or a recommendation for same? Seems it may be of some benefit,seeing as everything is controlled by black magic these days !
Yeah I do exactly the same, was going to suggest the DLC but wasn't sure if you could do it on the C6. There's not much else the Bluetooth reader does tbh, I tend to just use the DLC.I use one of these cheapies, works fine on my C5 with Torque app on Android phone...
ELM327 OBD2 Bluetooth OBD-II Car Diagnostic Scan Reader Tool Mini Android Torque | eBay
This super mini ELM327 Bluetooth OBD-II OBD2 car diagnostic scan tool designed for our Android head units This device can also worked with Windows phones and Windows computers. Simply plug into the OBD car diagnostic port and it will connect to the unit via Bluetooth.www.ebay.co.uk
...however, all codes can be read without any special equipment via the DIC (see Google/YouTube).
Solar panels are pointless you wont get enough amps out of that thing to charge anything.
You can get a tech2 clone or vx diag nano that will need a laptop and a bit of IT knowledge to set it up
Tech2 clone you can buy from Aliexpress I have both
Sorry you don't know what you're talking about
