NASA Moon capsule came home
If you cannot see NASA's cable station, then watch their Y-tube live below any time to see other NASA videos
The crew module of NASA’s Orion spacecraft has successfully separated from its service module at 11:00 a.m. CST in preparation for the crew module’s return to Earth. The service module will burn up harmlessly in Earth’s atmosphere upon re-entry over the Pacific Ocean. The Artemis I trajectory is designed to ensure any remaining parts do not pose a hazard to land, people, or shipping lanes.
Next, the crew module will perform a skip entry technique, dipping into the upper part of Earth’s atmosphere and using that atmosphere, along with the lift of the capsule, to skip back out of the atmosphere, then reenter for final descent under parachutes and splash down.
This technique enables the spacecraft to accurately and consistently splash down at the selected landing site for Artemis missions regardless of when and where they return from the Moon. During re-entry, the enormous heat generated as Orion encounters the atmosphere turns the air surrounding the capsule into plasma, which will briefly disrupt communications with the spacecraft.
Below are the upcoming re-entry milestones in CST:
11:20:14 p.m. – Crew Module Entry Interface
11:35:28 p.m. – Altitude 40,000 feet
11:36:02 p.m. – Forward Bay Cover Chute Deploy
11:36:06 p.m. – Drogue Chute Deploy
11:37:26 p.m. – Main Chute Deploy
11:39:41 p.m. – Splashdown
Earth’s atmosphere initially will slow the spacecraft to 325 mph, then the parachutes will slow Orion to a safe splashdown speed of 20 mph or less as it descends through Earth’s atmosphere. Parachute deployment begins at an altitude of about five miles with three small parachutes pulling the forward bay covers away.
Once the forward bay cover separates, two drogue parachutes will slow and stabilize the crew module for main parachute deployment. At an altitude of 9,500 feet and a spacecraft speed of 130 mph, three pilot parachutes will lift and deploy the main parachutes to slow Orion to a landing speed that ensures astronaut safety for crewed missions.
When Orion splashes down, the crew module uprighting system, also known as CMUS, deploys a series of five bright-orange helium-filled bags on the top of the capsule to upright the capsule in the event it stabilizes upside down. The system will deploy regardless of the landing position of the capsule, and it takes less than four minutes to upright the capsule if needed.
The capsule must be upright for crew module communication systems to operate correctly and to help protect the health of the crew members inside on future missions.
Way cool to watch this Eddy
Perfect landing, be interesting now seeing how they get this captured and lifted onto the navy ship
I have been interested in NASA since late 1950s and watched all the moon missions back then
I was lucky when working at GM I was part of 2 projects used for NASA
The Falcon 9 re-usable rocket fascinates me. When it comes back down to earth and lands upright on its target landing spot with pinpoint accuracy. I couldn’t believe it wasn’t a prank when I first saw that, unbelievable what they can do. Landing is from about 1:30 in this clip…..
If folks in the UK did not know it, NASA has their own TV cable station and 24/7 shows past and present content
Maybe can be watched in the UK ?
Last week, most of the week they showed all the Apollo moon landings
Reminded me when in school back then when teachers would roll TVs into the classroom, and we watched all those landings live
The Orion spacecraft has been secured in the well deck of the USS Portland. The ship will soon begin its trip back to U.S. Naval Base San Diego, where engineers will remove Orion from the ship in preparation for transport back to Kennedy Space Center in Florida for post-flight analysis.
Upon Orion’s successful splashdown in the Pacific Ocean west of Baja California at 9:40 PST/12:40 EST Dec. 11, flight controllers in mission control at NASA’s Johnson Space Center in Houston spent about two hours performing tests in open water to gather additional data about the spacecraft, including on its thermal properties after enduring the searing heat of re-entry through Earth’s atmosphere.
Recovery personnel also spent time collecting detailed imagery of the spacecraft before beginning to pull the capsule into the USS Portland’s well deck.
The recovery process involved divers attaching a cable called a winch line and several additional tending lines attached to the crew module. The winch was used to pull Orion into a specially designed cradle inside the ship’s well deck, and the other lines were used to control the motion of the spacecraft. The recovery team consists of personnel and assets from the U.S. Department of Defense, including Navy amphibious specialists and Space Force weather specialists, and engineers and technicians from Kennedy Space Center in Florida, Johnson Space Center in Houston, and Lockheed Martin Space Operations.
Orion is expected to arrive to shore Dec. 13 with offload expected on Dec. 15.
Yes, but look how many missions were done back then before landing on the moon and now 1 mission to test the rocket and capsule
A second mission that will be manned past the moon but not landing on moon and then 3rd mission to land back on the moon and more is this being tested to then uses all this hardware to land people on Mars
We need to do this before China does
Negative is slow pace., as 2nd mission not till 2024 and landing in 2025 yet NASA says they have parts now to build 5 of these big ass rockets with 2.5 million pounds of thrust
