After an unexpected snowfall yesterday we had brilliant sunshine this morning so I seized the opportunity to take the '71 for a short blast after weeks of inactivity. Car is running well and I'm enjoying the (very!) fresh air when a casual glance to check the gauges shows the oil pressure is around 5 psi. Although I hadn't checked it this time before setting off, on startup oil pressure normally rises - albeit very slowly - to around 25 psi where it pretty much stays constant regardless of engine speed. . I quickly curtail my trip and drive home.
Apart from the low pressure reading the engine sounds fine, it revs freely with plenty of power and no unusual noises. For some time there has been a hint of blue smoke from the exhaust on startup, particularly the drivers side bank but it disappears after warming up and I had decided that this was most probably due to worn valve stem seals, the replacement of which is a job on the list.
Now 5 psi is the pressure on startup. The fact that the gauge lifts off the pin suggests that the problem probably doesn't reside in the gauge, although I'll do an independent check with a test gauge, so I'm wondering what other possible causes there could be. Clogged filter seems unlikely since it been changed very recently. Clogged oil pickup could be a possibility i suppose but I'm wondering if anyone has experienced anything similar or has any ideas as to the likely cause?
