C2 VET
I'm just in the process of making C8 wheels fit my '99 FRC.
The wheels are at the machine shop having the centre bores relieved to C5 spec, the rears should be fine if I've done my sums right, 20x11 e64 is just about the same outwards as a z06 wheel @ 18X10.5 e58 and I know it will clear inboard as I already have 19x10 e79 with 4mm spacer carrying a 295/35/19.
I had a 305/35/19 set up that rubbed ever so slightly on those wheels.
The question is, has anyone done this previously as I'm thinking 295/30/20 but would like 305/30/20 if they fit both inner and outer parameters.
I know about the PCD, going to go wobbly nuts even though I don't think it's warranted.
