If it ain't broke, don't fix it......
While waiting for the front end chrome of my ’71 to come back from the platers I’ve spent many happy days trying to sort out what started as an intermittent misfire on one or two cylinders but developed into chronic misfire on all of them. Misfires are usually due to electrics or fuel, more often electrics, right?
So, starting at the sparking end I remove the plugs. They’re quite wet and sooty although whether this is a symptom of the misfire or its cause is not obvious. I clean them up and check their resistance and that of the HT leads and both are within spec. Moving back to the distributor I remove the cap and check for tracking. The cap is relatively new and shows no signs of breakdown anywhere. Remove the Rotor and check the points. They’re slightly worn but after cleaning they seem OK. However, I decide to get a ‘tune up’ kit and replace the rotor, points and condenser. At the same time I fit a new coil and replace the HT ignition wires with larger diameter low resistance cable. With everything back together I fire up and……no change, misfire still there. :(
So, it’s onto the fuel system. I have an inline fuel filter fitted between the pump and the carb and I replace this….
… then remove and strip down the carb – an original Rochester Quadrajet. With the carb stripped I take the opportunity to downsize my already three sizes over stock primary jets (to compensate for headers and a free flow exhaust) one size since I know the car has been running rich since I recently cured a vacuum leak. While dismantling the carb I notice that the needle valve return clip has migrated from the centre of the float arm into one of the slotted holes. Could this perhaps have been jamming the needle and preventing it shutting off fuel as the float rises, thereby flooding the carb and giving rise to my problem? I’m not convinced that the clip is strictly necessary since fuel pressure should lift the needle as the float drops. Still, I re-assemble the carb making sure that the clip is hanging from the centre of the float arm and not in one of the holes.
With the carb back together and refitted to the car and after a careful check of all fuel and electrical connections, I fire her up….no change, misfire still there. :(
OK, backtrack to the last thing I changed on the car before the misfire first occurred. This it turns out was the spark plugs. I’d replaced the stock AC Delco R44TS plugs with Accel 576S ‘shorties’ This was to make connection of the plug caps easier since I have headers fitted, reducing the gap between exhaust pipe and spark plug. This swap wasn’t essential since I could fit the plug caps to the standard plugs but the ‘shorties’ made it easier. Although for several weeks after fitting these plugs they had performed without problem and their resistance still checked out fine, I wondered if somehow they had degraded and were actually the cause of the misfire?
So, laboriously swap the plugs back to the AC Delco’s and with fingers crossed, fire her up again. Success! Motor runs without misfire although a bit lumpily since I haven’t set the dwell since fitting the new points. Correct this and she settles down to a smooth idle and with no misfire through the rev range. :):)
I’ve found reviews of Accel shorty plugs on several small block forums. Some people seem to be running them without problem while many others say they’re the cause of all sorts of problems – including misfires. Looks like I must have been one of the latter.
If I’d left well alone and lived with the restricted access to stock plugs I’d never have had the problem. If it ain’t broke, don’t fix it! Still, I now have my chrome back and I’ve repainted the grilles so I have another job to keep me out of mischief.
Have you checked the misfire at night with the hood open? - might give a clue if one or one HT leads are arcing to ground.............
How does the new plating look 👍😁
My cold, damp garage is an uninviting place to spend much time at this time of year but the recent mild spell has finally encouraged me to get the replated front end chrome back on the car .....
Before.....
....Stripped down.....
......and after.
The lighting conditions at different times of year make it difficult to get a good photographic comparison of the chrome before and after. The bumper was not in really bad shape before rechroming; surface speckling rather than any serious corrosion, but I have to say the new chrome really draws the eye and lifts the whole appearance of the car.
Before refitting I coated the back of the bumper and under-riders with a liberal coating of my favourite rust preventitive, Krown T40 and with everything loosely fitted and a lot of fiddling I've managed to reduce the uneven gaps between the lamp units and the under-riders that seem to characterise many early C3's. There are still gaps but they're reduced and more balanced than before; More fiddling may reduce them further but at the moment my patience is exhausted.
Was it worth the cost? As I say, the chrome wasn't that bad before replating but the difference in appearance of the car - to my eyes at least - is quite striking.
Before.....
......and after.
Oh dear....got the 'Vette out the other day just to give it an airing after being snuggled up in the garage for the last few months and noticed what I thought was a patch of mud or bird poo on the front bumper......
An attempt to wipe it off revealed that it was actually neither, but rust! It's only two years since all the front shiny bits were re-chromed and already there's quite a lot of deterioration. Closer inspection showed other small patches where the chrome was beginning to lift on the bumper.....
(Those aren't scratches, it's just where I wiped the rain off to take the pic).....and the plating on the light grilles was bubbling up too. These grilles are of course pot metal and difficult to chrome properly, but I've had Mazak parts re-chromed by the same Company before and they're still sound many years later.
Took the car back to the plating Company today and they agreed something was definitely wrong. They suggested I get the chromework off again for a proper assessment of the problem - so it looks like I've got a job when it's a bit warmer and the rain has stopped. Don't you just love old cars? :cry:
Seems like insufficient preparation of base surface prior to plating. Company I previously worked for used a company known as Essex Metal Finishers, based in Ongar. They used to chrome plate items manufactured from brass sheet for us (so rust issues). Very high quality work, the best chromers in our trade (decorative switches and sockets) - their process vats were big enough to do car bumpers and components and other large items........but (and perhaps like other platers) they used an outside specialist to straighten and weld-fill/repair any rust damage........and that perhaps is where it can all go wrong if other chromers reply on 'others' to dress and prepare the metal. The cost of high quality brass sheeting was prohibitive and competitors would generally use a cheaper quality material which would often have impurities........these would show-up in the surface finish and often corrode through the surface of the chrome. In the same way as good quality car paintwork the preparation of the surface being finished is critical for the longevity of the finished item. Best of luck.
Seems like insufficient preparation of base surface prior to plating. .....
I think you are probably right Rosco. If the parts had been correctly triple plated - and the Plater confirmed that they certainly should have been - then if the base metal had been correctly prepped I would expect any separation to be confined to the nickel and chrome layers with the copper still adhered to the base. It seems that all the layers had lifted suggesting inadequate base prep. A Friday afternoon job perhaps?
I've had excellent service from this Plater over the years on several automotive jobs and this is the first time the result has fallen short. If when the cause has been determined the responsibility lies with the Plater I'm confident they'll honour their warranty pledge.
However, first I've got to get everything disassembled - again, :(
What bummer not to mention frustrating ! Poor prep was my initial reaction too when said the job was only two years old . Hope you get sorted ok and not hit in the wallet again !
Well, got all the front shiny bits off again - it's much quicker the second time! :)
Now to see what the Plater thinks....🤞
That is frustrating, looking at that collection of parts and knowing just what my underiders cost to re plate, that is a big bill right there. Hopefully they will put things right as your vette is a mobile advert for their work. 👍
Well, finally got my rechromed brightwork back on the front of the car :) - I keep forgetting that reassembly always takes ten times as long as disassembly.:(
So, if summer does actually put in an appearance this year, we're good to go. :)(y)
Incidentally, when I collected the bumper the plater mentioned that after stripping down they noticed 'staining' on the bare metal where the chrome had lifted. This they normally associate with chemical attack by, for example, brake fluid. I wasn't aware that brake fluid could attack chrome but googling certainly confirmed that this can happen. As far as I know I've never spilt brake fluid anywhere on the car as I'm well aware that it can be disastrous on paintwork. The platers were nevertheless quite prepared to rechrome for free, but it's certainly something to be careful about in the future.
