C4 C100 bulkhead connector
purple charlie
Before i get in a mess, presumably this is the c100 connector, cant get it apart has been sealed with black mastic.sits behind the battery
Llewelyn
You can get it apart and the mastic is factory. Just be patient and careful - I will say if you're tracing a fault, unless you're 100% sure it's probably not that connector. They are very well sealed.
