John McIntyre
For sale.
1968 Chevrolet Corvette. Convertible, finished in super non-factory blue, with black top and interior. Car is always garaged. Car is located in Littlehampton, West Sussex.
Mileage
65,933
Engines.
Original.327. Cubic inch. 300 HP has been removed as needs a rebuild.
Current. New Blueprint 383. Cubic inch. Stroker. 441. HP. 800 miles only since installation and break in (500 miles).
650 Cfm Holley.
MSD Ignition
Headman 4-1 headers.
Aluminium 3 core radiator.
Bespoke tig welded Stainless steel exhaust 3 inch o/d, 1.5mm wall thickness
Gearbox. 3 speed. TH. 400. Top and bottom seals replaced. Including filter 1,300 Miles ago. New gearbox rear bush.
Rear
New AC Delco shock absorbers, strut rods, camber kit. Posi Drive differential rebuilt 1,300 miles ago. Including. seals. bearings. clutch pack. and correct Posi gear oils.. New differential front bush.
Wheels and tyres.
Fitted with. BF Goodrich 255/60’s. 15 inc 8 J. Rally. Steel rims. The 8J rims have been shot blasted and powder coated. 7 J used as spare To help clear spare compartment.
Cover
Hamilton Classics Indoor Car Cover
New parts fitted this year. 2025
Windscreen with Blue Tint.
Windscreen wiper motor.
Wiper Dash Switch
XL push rod to clevis power brake
Back up light switch/neutral safety switch.
Power Brake Booster
Vented fuel tank cap
Custom 3 inch o/d stainless steel crossover exhaust.
Spares and parts
I have a large number of parts mostly new in addition to below.
4 original. Trim rings. In fair condition.
Inner tube. To suit. 7 or 8 J rims.
Original Master cylinder.
Brand new. Master cylinder.
Front and rear set of brake pads. new.
Original brake booster. Replacement brake booster. Used. Not working.
Original wiper motor. Not working.
Original brake calipers.
Caliper refurb kit
Original radiator
Original AC compressor bracket and pulleys
Happy to upload more images (older) if you would like sight.
If you are interested please call or PM me.
John McIntyre
07710 461 901
Mileage
65,933
Engines.
650 Cfm Holley.
MSD Ignition
Rear
Wheels and tyres.
Cover
Wiper Dash Switch
Power Brake Booster
Spares and parts
Caliper refurb kit
Original radiator
John McIntyre
07710 461 901
