Adjustable Shockers (in-car?)
Given that 'we' can buy 2 way adjustable dampers for our cars - to allow us to spend time grovelling under the cars/removing suspension components to adjust a pair of tiny damper mounted dials and change compression/rebound settings in advance of road conditions we 'might' be next using the vehicle for.......so comfort - sports - poor surfaces - track - drag use.
Some upper end motorcycles have dampers with remote adjusters that are easy to access - more advanced later bikes may have electronic 'on the fly' damper adjustment controls on the handlebars.
Why hasn't any of the top-end damper manufacturers come up with dashboard controls for their two way adjustable car dampers?
There is another path to get fully adjustable shocks and not having to jack car up to make setting changes
I use Penske Race shocks which have multi adjustment functions
Either on the shocks or also these have pressue tanks as I show below that allow making changes where the tanks are mounted
Best as I use is Nitrogen as allows higher PSI, pressures injected into the tanks
Can tailor each shock by the amount of Nitrogen pressure and also has an 8 positions knob to adjust how each shock functions
These also were designed so they can be mounted upside-down so less unsprung weight
Each shocks canister is mounted as I did for my C5, so adjustments can simply be done up top and easy to reach
Remember the old adjustable friction dampers on vintage cars ? All you needed was to reach under the wing ( fender to TeamZR1 ) with a spanner . Easy peasy !! 😁
Even better on an old bike with girder front forks - friction damper adjustment knobs are just a little way forward and down from the handlebars - the brave could perhaps make any changes 'on the fly'......perhaps. In those days most bikes had rigid rear-ends.....only the odd hi-end bike like a Vincent had friction rear dampers.
One of my fellow apprentices had a Vincent Black Shadow back in the late 1960`s . It was one hell of a machine even though getting a bit long in the tooth by then . We used to go hooning up and down the A45 in Northampton on it during our lunch hour ! No crash helmets in those days either !1949-vincent-black-shadow.jpg
Strange thing that back then we didn't seem overly bothered about top speed. Didn't wear protective gear, no 'lid', nothing - not a 'cool' look wearing a helmet (or so we thought back then). People make a big thing today 'pulling' a wheely. My 1955 early iron headed Tiger 110 surprised me one day when getting some extra grip on the rear-end pulling away hard from a standstill and popping a low level wheely - frightened me to death at the time as the bike drifted from the left kerb of a heavily cambered road over to the right side kerb. Had to stop and compose myself (checking underwear probably)
:eek:
:eek:
