Fixed a long term cold engine running issue
All the time I've had my Corvette its had this issue that when the engine is cold, aka for 5 -10 minutes after engine startup, it would try to cut out if you went to pull away from a standstill, and didn't feel especially powerful until warmed up. I figured its was an old car, and fair enough as I'm not great until I've warmed up too. I don't drive it hard, so it didn't massively bother me and I just adapted to it. Once up to good temperature it seemed fine.
That said over the years I've had the car I've tried lots of different things including:
New carb, to eliminate any issues with the chinese copy of a Carter carb that came with the car.
New intake manifold.
New HEI distributor (though it had one before), complete with new plugs and leads.
New "headers" exhaust.
New PPV (?) valves from engine to carb.
Eliminating air leaks from vacuum hoses.
A whole tuning setup on a rolling road.
Probably other stuff I've tried and forgotten about.
Obviously all the usual service items etc too.
Each bit seemed to help, especially the new carb and having it tuned. That made the car much better when warmed up, but still had this cold issue, though not quite so bad. Like I said, it didn't bother me enough to really fix it, and most of the stuff listed above I did because I wanted to update the car and get rid of some of the old stuff on it. At no real point was I specifically trying to fix this issue I had, other than getting a new carb to replace the cheap chinese copy. Though over time, the issue seemed to get a little bit better and i didn't get as many "cut outs" when pulling away - or was I just better at managing it?
Anyway, its been ten years since I've owned the car now, and during this summer for some reason it started to smell a little bit petrolly when I was driving it. Not overly bothered again, old carb car etc. But looked into it and common solution is the petrol tank cap gasket has gone. Had a sniff around my cap, and yeah, it did smell a tiny bit. So I thought I may as well replace it. That's when I started looking into the part I needed to replace.
You see, my C3 is a 1968, so all bets are off when it comes to parts for a one year only model. In my research I found most replacements come with a new cap as well. Problem was, all the 1968 caps + gaskets I was finding didn't look like the cap that was on my car. The main difference being the outer shape of the cap, and the writing on it. The writing on mine said "Non-vented", whereas the 1968 caps I was finding said "Vented" on them. Did some research on why, and it turns out early C3 petrol tanks vent out of the petrol cap, whereas later ones use a charcoal canister in the engine bay and the petrol tank vents out through a tube to said charcoal cannister - the reason being is better for the environment that the fumes go through a charcoal cannister instead of direct to air. I can only assume that the previous owner of my car in the USA put a "non-vented" cap on because they are more plentiful and cheaper. Oh and for those like me that didn't know - venting is required to equalise the pressure in the petrol tank. Either from the fumes, or from replacing the petrol consumed with air, otherwise you form a vacuum in your tank and the fuel pump has to fight the vacuum which leads to the engine not getting enough fuel and could cut out / splutter / feel low powered etc.
Quick contact to EMC and a new correct 1968 vented cap is ordered in the hope it cures my slight petrol smell. It seems to be better now, so worth doing. It took me a few drives of the car before I realised that I wasn't having to "catch" the engine when I pulled away from a standstill when the engine was cold. It'd been second nature for me to do it for 10 years without realising, just the character of the car I'd adopted to. As soon as I realised that, I put the car in the garage and left it for a few weeks to go properly cold. Then started it up took it for a drive and paying full attention to my pull aways and deliberately pulling away a bit quicker from cold. Needless to say there was no issues, and car now pulls away fine when cold and seems more powerful when cold too. I can only assume that previously when my engine warmed up previously that something just opened up a bit to allow an air leak or something to allow the tank to vent, or was forced open by a warmed up engine, and thus engine ran better when warmed up. Gosh knows what, there aren't any leaks or anything anywhere that I've found. But right now the car is a different animal when cold.
TL;DR:
1968 C3 had cold driving issues, solved by changing a petrol tank cap from a wrong "Non-vented" one to the proper 1968 "Vented" one.
  • Like
Reactions: Emc
An interesting 'set' of circumstances Kieran - it make one wonder if your (now hopefully ) 'vented' fuel delivery/tank set-up managed to 'hold' a partial vacuum from one start-up to the next? - it must be this partial vacuum in the tank caused by use of a non-vented fuel cap (on a vented system) that perhaps the fuel pump had to overcome.
I'm guessing your car has a single pipe fuel supply system........my '68 certainly 1000018647.jpgappears to have a vented OEM cap and a dual flow/return fuel supply. The idea behind that it supposedly is to circulate unused and probably heated-up fuel in the supply line where it runs through the engine compartment fairly closed to the passenger side exhaust manifold/header. Guess it works fairly well as I don't generally have the typical percolation issues that so many cars of the period suffer with........but give us a hot day............
It seems the application of the dual feed/return system is sporadic on both SBC and BBC powered cars......can't comment for later years.
Look carefully and you'll see 'Vented' on the cap.
Yeah that's the cap I now have with "VENTED" on it. My original one that came with the car when I bought it from USA had a slightly different shaped one and said "NON VENTED" I think. I can't quite remember the years now but I think its something like 1968 - 1970 is vented cap, then afterwards not vented using the charcoal cannister instead.
Mine definitely doesn't have a cannister and doesn't appear to have any tank lines on the drivers side. As far as I remember its all on the passenger side. Will have to have a look again at some point to confirm, but ultimately the car runs better now. So yay, added bonus.
Interesting Kieran, and I’m pleased your car run better now. I just cannot understand the connection between the vented cap and poor cold running though!
Is your cap vented in both direction then? I have a vented cap but it only vents in one direction - to allow air to be drawn into the tank. The fuel tank plumbing changed through the years I know, but I always thought the charcoal canister was just employed to capture vapour forced out from the tank when it’s pressure increased - mainly due to air expansion on a hot day. Then a pipe from the canister to the air cleaner enables the fuel “held“ in the charcoal to get drawn back into the engine when it’s running.
Incidentally, one thing that has made my car run noticeably better from cold was after I added much more initial timing (22 degrees) That wasn’t why I did it though! This is a trick you read about in some of the engine tuning articles to give the engine more power off idle revs. Theory being you don’t have to wait for the mechanical timing to “spool up” via the centrifugal bob-weights to give it the timing advance it likes. I’ve locked out the mechanical timing to limit the all-in timing at 34 degrees. The better running from stone cold was purely an unexpected side-effect but a very helpful one. The car previously didn’t much like cold running and needing a bit of clutch dipping to get moving. No choke on my Holley DP.
GM as to 1968 5.3L C3
Fuel Tank & Filler Cap​
The fuel tank is an integral part of the Evaporation Control System. In order to collect as much vapor as possible, the fuel level was reduced by lowering the filler neck from the highest point of the tank by approximately one inch.
This allows room for expansion and vapor collection on top of the liquid.
Fuel venting occurs at three positions on the tank.
These vents allow fuel and fuel vapors to flow from the top of the tank to the liquid-vapor separator.
In order to prevent a vacuum collapse or pressure expansion,
the fuel tank cap has been modified to release excess pressure or allow additional air to enter during stages of high vacuum.
The cap also has dual locking action.
The second set of ears on the cap provides a slow bleed of any residual fuel tank pressure when the cap is removed.
I must confess I don't know the exact dark magic behind it. Just that the early C3s had a VENTED cap and NO charcoal cannister. Then later on they put NON-VENTED caps on at the same time as charcoal cannisters.
From what I understand, my VENTED cap is actually to allow air to be drawn in when the tank creates a vacuum (aka fuel being used). The issue I had was the vacuum in my tank wasn't being equalised as it wasn't vented, so my fuel pump was fighting that when cold. As to why it was better when warmed up, I have no idea and can only assume that when the vacuum got too high after running up to temperature that it forced an air leak somewhere (probably a bad gasket on the old cap and why it smelt a bit petrolly), and thus it ran better as the tank got equalised. Dunno.
As to how the later charcoal cannister NON-VENTED cars draw air into the tank, I have no idea - like you I thought the charcoal cannister was to capture the fuel vapour stuff from the tank when the pressure was too high and allow it to be dealt with more environmentally better. Aka the stuff on my car (without the cannister) that would vent it to atmosphere when I opened the petrol cap, which isn't environmentally great (but smells nice! :ROFLMAO:).
Mechanical fuel pump not on passenger side of engine K?
Yup, mechanical fuel pump on the passenger side of the engine. Its deffo the original engine as the block has its original number stamped on it. I have theories that the heads aren't original though, but not taken it apart to check the numbers.
Typical GM evaporative emissions schematic - see how its linked from charcoal cannister with PVC and EHR valves to carb. Fortunately with earlier C3's we don't have that stuff. Biggest worry later cars is someone choosing to de-emission their car, ripping-out all the stuff, not correctly blanking-off piping etc and creating long term 'niggly' difficult to diagnose running issues.
Yeah the removal of the fuel vapour build up I understand with the charcoal cannister. Just unsure how NON-VENTED later cars can suck air into the tank to equalise out the vaccum caused by consuming fuel. I just kept reading that it was vented via the canister, but thats just vapour vented out, not fresh air vented in. Or maybe with a vacuum in the tank it does just suck air in through the charcoal cannister? Who knows. Needless to say it works :ROFLMAO:
I'm reminded of using modern daily drivers - petrol yes, hybrid too. Never really noticed the vacuum build-up in the fuel tank when removing the filler cap except with the tiny (35 litre) fuel tank in the company BMW plug-in hybrid I was using about 5 years ago. There was a really significant 'gasp' of air when removing the filler cap. Having said that with all engines now having fuel injection - guessing that most fuel pumps on injected cars are powerful enough to overcome any vacuum build-up in the fuel tank.
