As the voltage is dropping back to normal level you know the voltage regulation is working.
First step is to check all the voltage readings with a decent digital voltmeter. Check them right at the battery terminals.
How old's the battery? I'd suspect a weak battery causing the system to try to overcharge before the regulator pulls things back to normal. Just because a battery can crank the engine doesn't mean it's "good". The best test is a high current drain test at your local battery centre (or Halfords) although you can get a pretty good guide from DIY voltage checks.
Check the voltage in three different circumstances,
1. Check after the car's been left standing overnight on a mild night and before anything is switched on or the engine is started. (Use the car previous day to make sure the battery was fully charged before parking up.) A "good" battery will show at least 12.6v. Anything under 12.4v and your battery is on the slide. Below 12.3 and it's time to replace it.
2. Check again during the first minute after starting, while the dash is showing 17v.
3. Check again after the dash voltmeter has settled back to 14v.
I'll be interested to hear what you find.
If a battery is weak I don't spend money on chargers/tenders - they can't breathe new life into an old battery. Just buy a new one.
