Team zr1 thank you for your response.will I be able to access the pipeline by taking of the inner wheel arch.
You're Welcome
Yes, that tank is mounted off the A-pillar and sits above where the PCM and TAC controllers are behind
that inner fender
Towards the bottom of that fender is some small screws and a section of that comes off to get to the PCM
and look for the broken hose end to at least plug it off so no vacuum lose to engine
Not sure if that is enough room to get higher where tank is, if not that loosen that inner fender to reach behind
for tank location
For now, you could do is back of the engine in the
center by firewall (
IF you can get your arm back there and good lighting)
you can see from the passenger side is the MAP sensor, and next to it is the small like 1/8th inch vacuum how fits onto a nipple,
That hose is inside the wire loom that goes to the PCM and end of that hose than goes to that reserve tank
IF You could take the hose off by MAF and plug that nipple, so the engine does not lose vacuum when the hose is off
That allows the engine to run better as the PCM commands the engine depending on what MAP output is and with
that hose off by that tank causes vacuum leak and PCM commanding engine incorrectly
Image of intake manifold and where that small hose connects to back
