MilkyNoSugar
I have the following new and unused gaskets for a 454 Mk IV Chevy engine
Ideally collection from Leicester, or I could post if needed.
Sensible offers considered.
- 1 Pair of Felpro Head Gaskets - 8180PT2 - £45
- Felpro oval port intake manifold gasket set with manifold restrictor insert MS90665 - £30 for the set
- 1 set of 16 Comp Cams Valve Seals 3/8" PTFE 505-16 (These do not fit standard stems without machining the tip of the stem) - £30 for the set
- 1 set of 16 Felpro valve stem seals - rubber umbrella type - 5P591 (These will fit the standard stem, but possibly not if you have dual valve springs) - £10 for the set
- 2 x Rol gaskets Exhaust Gasket 60083 - £15 for the pair
- FelPro MS90206 Exhaust Manifold Gasket Kit (1 pair of gaskets) - £20
- 1 x Fel-Pro 70836 Exhaust Gas Recirculation Valve Gasket - £10
- Pioneer Cylinder Head Bolt Washers 852096 (set of 34) - £25
