After the Nationals I pulled the engine and gearbox out. The gearbox needs a rebuild because there’s a problem selecting second gear. I’ve got a new alloy sump for the engine, so it was easiest to remove both engine and gearbox together. I‘m also going to fit a Hurst shifter.
I had the gearbox rebuilt professionally in 2011. It was good for a while, then it started to pop out of second gear when I lifted off at higher revs. I lived with that. Then second gear synchromesh started to play up, particularly at higher revs and also got worse when then everything was hot. I‘ve been double de-clutching to get around that problem. This is all a bit of a pain and was affecting driving enjoyment so time to investigate…….
