C3 aluminum wheels
Oli
Hi - as a near-daily driver (my C3 is my only vehicle), I would like to refurbish my wheels for a tidy look.
i am also keen to reduce the amount of elbow grease I spend polishing….
what options do I have, for a more permanent protection
is there an option to keep the “polished aluminum “ look?
there is a little bit of damage- nothing too bad, but would need a professional to take care of it
any recommendations close to / in Berkshire?
much appreciated
oli.
I suppose once you’re happy with the polished finish, you could lacquer them, giving them a few coats. Not sure how long this will last tho.
I recall 'back in the day' having spent serious money on a pair of Woolferace wheels and looking to retain the 'shine' I sourced a spray can of clear acrylic lacquer specifically sold to 'protect' polished all0y wheels. And at first it did just that.......maintained the original shine...........until the fist dog cocked its leg-up and pee'd on a wheel. And yiou know what happens next? - other dogs will also 'mark' the wheel. The lacquer then becomes discoloured. TBH the lacquer loses its gloss anyway with age........and then you have the issue of trying to remove the clear lacquer!
Oli
You sort of confirmed my suspicions, which is that there is no long term solution to retain the polished aluminum look. Any clear coat would deteriorate and look worse . And I don’t want a coating of any kind. If there was a miracle solution it would be known and documented - i haven’t seen anything conclusive.
Thanks both
Thanks both
I'll post some details about my current polishing regime a little later this afternoon.........it may help
  • Like
Reactions: Oli
I will post (my experience) shortly - and it isn't too negative.......elbow grease perhaps as Nassau comments
That’s always been the trouble with aluminium wheels. Look great when polished but from then on it’s all downwards until they are done again.
I remember my first set of woolfies ( wolf race ) . Fresh out the box they looked the biz, couple of months later all dull and not so good looking. Same could be said for all the others about on other cars, so I was not alone.
  • Like
Reactions: Oli
OK, my thoughts and actions. It was only last week at our Essex regional meeting that I saw a members '78 Anniversary C3 parked outside looking absolutely like new with highly polished Vette alloy wheels.
TBH the wheels were such a high gloss and so impressive that I didn't really take any notice of the car (I should have - as someone mentioed to be the following day that it was a recent aquisition that was bought over from the 'States with less than 1000 miles!)
Others might want to correct me but I believe as stock from GM their wheels were supplied with a satin finish (now known as diamond cut?) and that many owners later polished them (or were certain years OEM polished?)
Anyway it got me thinking about the rather special aftermarket wheels I bought for my C3 some 15 year or so ago. Refered to as 'Billet' wheels, the rims are manufactured from solid high grade aluminium and then 'shaped' by a process know as 'spinning' on a lathe before being welded to the cast or forged spoked wheel 'spiders' or centres.
My rims were described by the manufacturer as being 'mirror finished' and that abrasive polishes (like the traditional Autosol chrome/aluminium paste) that we would historically use on motorbike engines, exhausts and chrome bumpers, rocker covers etc on our cars is a big 'no-no' to use and will create a myriad of tiny scratches to the 'mirror' finish.
I suspect that many C3 owners with ally wheels use this or similar polish........and TBH its fine and comes up with a nice finish on raw aluminium.......but it certainly dosen't give a 'mirror finish' akin to chrome plating.
Polishes
There are ultrafine paste type polishes made or supplied by comanies like Mothers aand Meguiers which have quite a delicatr composition and in fact work exceptionly well. American Racing do (or used to) do a wadding type billet wheel polish (like the old school Duraglit brass waddinf polish) this is also a really delicate and easy to use product.
How often to use
I do less than 1000 mike pa (often significantly less) - my regime is at the start (and end) of the season I remove all four wheels, wash them and the tyres throughly (usually allowing a day to hand polish all inner and outer surfaces of the wheels). I then apply a coat a coat of wax polish (hard wax or liquid) and polish off.
This generally maintains the polished finish quite well, obviously washing the wheels down after a longer run and when brake dust or road crud is visible.
And avoid taking the car out on salty roads during winter.
You'll need to be observant during the winter 'lay-up' period with any dampness creating issues with the finish while the car is garaged. Plenty of wax is generally the answer.
Your next task to try and initially achieve that mirror finish is simply 'how to'? - hours and hours of polishing, and probably a combination of machine and hand work.......or send to a wheel refinisher? - your descision...........
Products not to use (for some) and a typical billet wheel type polish (you should use)
  • Like
Reactions: Oli
You could powder coat them in any type of color and would last a long time
I did that for the rims on my C5 22 years ago, and they still look great
That’s the trouble with aluminium, black grime will always come off sometimes even when highly polished
The C3 aluminium wheel certainly is a good looking wheel tho. This one was nicely polished before I sold the car.IMG_1033.jpeg
  • Like
Reactions: Oli
Oli
Chemically analyse that 'black grime' and it will be microscopic particles of aluminium.
Polishes
How often to use
i have the same Autosol tube in my garage - you just reminded me that I am running low!
thanks for the very comprehensive answer
Depending on how much you use, I think is cheaper to get the tin. It’s about £25 including post on eBay.
