That is an old analog tester and finding cables for it will be pretty hard
Snap-on PDM MT500 Precision Diagnostics Meter (PDM) is a highly versatile diagnostic test instrument specially designed for automobiles and light trucks. Numerous features have been incorporated into the design of the MT500 to make it accurate and easy to use.
These include: 10 Megaohm Minimum Input Impedance Numerous Test Ranges Color-coded Switch Positions & Test Lead Jacks Digital LCD Display Polarity Sensitive Test Leads Ignition and Fuel System Dwell / Duty Cycle Measurements in either degrees or percent Internal Battery for Portability. Mounted on rolling cart,
There are 4 jacks at bottom that the test leads go to mostly for looking at timing and dwell readings
This is not a OBD-I scanner and would not plug into the DLC
If not having a scanner there is a way to jumper 2 pins on the DLC and then on the dash it would flash a light you could to see what and if any error codes are present
