Yeah , I got fooled on mine as what look like hex head screws are not in reality !Afraid it will have to come out from the back and you'll need to at least loosen all the centre console to get the gauge panel out. I found it a bit of a fiddly job.
About to attempt this to get to my oil pressure gauge. I too had read that there are two screws at the bottom connecting gauge panel to console and it is easy to crack things if you miss them. I didnt see these mentioned in teamzs video. Mine is a 72, in the video the guy left the shift console in place I think and just pulled the gauge console forward from the top. Any tips or thoughts welcome. TiAJR your video looks to be an early C3. On my 78 (and the original poster's gauges look to be the same as mine) there are an additional 2 screws that attach the gauge panel to the centre console. I'm pretty sure I also had to remove all the other attachments holding the centre console, in order to move it back a bit to get the gauge panel out.
About to attempt this to get to my oil pressure gauge. I too had read that there are two screws at the bottom connecting gauge panel to console and it is easy to crack things if you miss them. I didnt see these mentioned in teamzs video. Mine is a 72, in the video the guy left the shift console in place I think and just pulled the gauge console forward from the top. Any tips or thoughts welcome. TiA![]()
I guess your car probably has the same gauge console as the video, but I don't know if the 2 bottom screws are there or not on the early cars. Another thing I remember is that my radio has a support bracket on the back that would prevent you removing (or tipping) the gauge console without first removing it. Don't know if this is standard, as a previous owner had already changed the radio.
Thanks john g. I did see another video of a gauge console removal and someone had two wing nuts that he reached after removing the shift console.I guess your car probably has the same gauge console as the video, but I don't know if the 2 bottom screws are there or not on the early cars. Another thing I remember is that my radio has a support bracket on the back that would prevent you removing (or tipping) the gauge console without first removing it. Don't know if this is standard, as a previous owner had already changed the radio.
