GM's first makeup standard was labeled dexos1
Then next version was dexos2
Newest version and required for Corvettes is dexosR is is backward compatible to versions 1 and 2
Europe required more cleaners and is labeled dexosD as more diesel engines there
Also, labeled as dexos ESP
GM dexos website as this shows what versions are newer but can be used with older versions as are backward compatible
Website shows for each version what vendors are approved and their license number
GM dexos
Mobil 1's website shows all types
The right motor oil makes a difference. Regardless of whether your car or truck is new or a long-standing family member, the motor oil that goes in the engine does make a difference.
www.mobil.com
Use this webpage, enter your year, model, and it suggests which Mobil I to use
Get the best Mobil 1™ motor oil for your Chevrolet to help keep your engine in excellent condition.
www.mobil.com
As side note :
When I worked for GM engineering in Warren, Mi I had a testlab in the underground of manufacturing B building
Few labs down from mine was Mobil 1 and they for many years there do testing to assure as new GM products are made
Mobil 1 works with engineering to assure the makeup of oil works well with the new engine designs and were involved with GM's makeup of dexos versions
