Just to put the cat among the pigeons - for the 30 years we've owned the Corvette I've used the cheapest fuel I can get! Supermarket has been the brand and 95 octane.
BUT - for reasons I won't go into, the timing has been set to be a tad "aggressive" in recent years. And, the propensity for anywhere here to replace 95 unleaded with the dreaded E10 means that I've started to put 98 in it. It seems to like it! That said, if your timing is stock then you may not need it. Interestingly, I've never run any of my cars on Shell of any kind because I found that they just don't like it! That may be the way I have tuned them, but I actually thought I had a serious problem in one car, until I switched back to a cheaper fuel.
The key thing is to avoid Ethenol at all costs - the older fuel systems just cannot cope with it and rubber and plastic parts will begin rotting out. Not sure what the situation is over there now, but if you can avoid E10 then do so. Or, add Millers EPS, proven to combat the harmful effects.
