trevbeadle
Can someone please post a photo of the routing for the water pump heater hose?. I have just replaced the wp on my 350 and discovered that the heater hose has become chafed through. The routing from the water pump across before it goes rearwards takes it very near to the bracket supporting the A/C pump. Should it route in front of the A/C compressor mounting, underneath between the bracket and the suspension or behind between the bracket and the block above the exhaust manifold? Its obviously been chafed through before as there is an inline hose joint under the radiator expansion tank as the hose goes rearwards.
Thanks
			Thanks
