UK67
Found this mod on a US forum to improve on the non existent self centering of the Borgeson PAS. Remove the top control arm and slot the cross bar mounts 1/4 inch. This means you can move the bar rearward and so increase the caster angle to about 4 degrees. The top control arm assy can be easily removed by first compressing the coil spring and then breaking the top ball joint. You will need to find someone to mill the slots though! May be useful on standard PAS as well but not sure.
Haven't driven far but definitely an improvement and gives a more relaxed drive without continual steering adjustments
