Hi, are people ok with jacking under the diff to raise both rear wheels off the ground . Any thoughts or suggestions? Tia
thanks, I want to get rear raised to have a go at the handbrake adjustment , two jacks at rearjacking points on chassis best?Never raise the car using the diff, by doing this you risk breaking the rear spring mounts on the rear cover, corvettes were not designed to be jacked up this way.
Always use the frame rails. I usually jack the car with the jack positioned more towards the centre of the car than the actual jacking points as shown in the drivers manual. Then, I slide in the axle stand to about where the actual jacking point is, then lower the car onto the axles stand. I never work on the car with just a jack!thanks, I want to get rear raised to have a go at the handbrake adjustment , two jacks at rearjacking points on chassis best?
Sounds good , i quite like the length of 4x2 under the rail so spreading the load , saw it on line, wrapped a piece in felt and stapled in place , havnt tried it yet. Do yo do one side at a time or two jacks at same time. Just wondering if jacking one side flexes body at all. Am seriously looking into a 2 post wheel free lift for the new shed. Will make maintenance and fettling a doddleAlways use the frame rails. I usually jack the car with the jack positioned more towards the centre of the car than the actual jacking points as shown in the drivers manual. Then, I slide in the axle stand to about where the actual jacking point is, then lower the car onto the axles stand. I never work on the car with just a jack!
Good move - never, ever get under car with just a jack alone and remember if you jack and try to support the car up from one side only the underside of the chassis rail will not be parallel with the ground and thererfore at extremely high risk of slipping-off the jack (or axle stand).Sounds good , i quite like the length of 4x2 under the rail so spreading the load , saw it on line, wrapped a piece in felt and stapled in place , havnt tried it yet. Do yo do one side at a time or two jacks at same time. Just wondering if jacking one side flexes body at all. Am seriously looking into a 2 post wheel free lift for the new shed. Will make maintenance and fettling a doddle
I am very lucky .I get the use of a post lift at the workshop for anything other than quick jack up jobs like brakes as long as a race or rally car is not hogging itSounds good , i quite like the length of 4x2 under the rail so spreading the load , saw it on line, wrapped a piece in felt and stapled in place , havnt tried it yet. Do yo do one side at a time or two jacks at same time. Just wondering if jacking one side flexes body at all. Am seriously looking into a 2 post wheel free lift for the new shed. Will make maintenance and fettling a doddle
If Iβm jacking the rear end up I will jack under the diff - under the spring clamp plate to be precise.Hi, are people ok with jacking under the diff to raise both rear wheels off the ground . Any thoughts or suggestions? Tia
