L79 350 bhp Engine - SOLD
UK67
Removed in July from my C2. Has been running well over the 10 years of ownership and took a short video prior to replacing with a Blueprint injected 383 stroker. Old receipts show the carb and water pump were replaced in 2012 by previous owner. If it had been numbers matching I would have kept but CE8 29191 tells me it was a warranty replacement years back. The block casting number tells me it is a '67.
Only negative is a slight leak from 2 piece rear main seal. I did replace it 5 years ago but obviously didn't do a good job because noticed recently it's started to leak again.
I'm thinking £2500 ?
